building 400 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 08:36 AM
building 400 sbc
I have a stock 76 400 sbc in good running condition,i want to pu it in my 69 Acadian,it has a t350 trans with 308 gears, i want to put 3973370 64cc heads on it with a adelbrock intake & 650 edelbrock carb,these heads are the same as 186 heads.i won,t rev the motor over 4500, it,s a driver not a race car,the heads are stock with 194 150 valves. what compression will the motor be,it had 76cc heads.what is a good cam for this motor,im looking for decent milage for a driver. the original 307 2bbl gets about 17 mpg hwy. if i could get the same with more power that would be a bonus,it has duel exhaust also.all info appreciated,Im not touching the short block other than new oil pump ,double roller chain & gear & lifters. cam?
Old 01-26-2013, 10:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Without knowing the dish size of the piston and the piston deck clearance (how far the piston is down the hole at TDC), there's no way to say w/any real amount of accuracy.
That said, if the dish is 24cc and the quench is 0.040", the CR will be about 9.5:1 w/stock bore and stroke and a 64cc chamber volume.
Old 01-26-2013, 11:29 AM
400 sbc
orig it is 8.5 to 1 in 1976 with 76cc 882 heads.
Old 01-26-2013, 11:30 AM
The original pistons have a 22cc dish
Old 01-26-2013, 07:56 PM
vinniekq2's Avatar
The 400 economy engine I built years ago had stock short block with sig erson tq-20 cam,holley street master intake,625 carter,1 5/8 headers,2.73 gears,,,20 mpg and low 14s in an 86 monte carlo
need some help building my 400 sbc :) atcoscrazyest69 Engine 19 01-02-2012 08:44 AM
Help building a 4-500 HP 400 SBC timmy estes Engine 2 12-01-2010 11:37 AM
Budget building a smogger 400 SBC in CA Dizturbed One Engine 7 07-11-2010 10:43 PM
Building BIG HP 400 SBC Sampson Hotrodding Basics 11 04-04-2004 12:52 AM
need help building a 400 for 69 bronco hogan400 Engine 10 05-27-2003 03:36 PM
