Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a 489 stroker
Old 09-15-2012, 01:36 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
Internal balanced cranks are usually preferred.If the power is reasonable then let your budget decide what route to take.Piston to valve should always be checked when assembling an engine.The HD 7/16 GM rods are pretty good.If you need better than stock, then check with carillo or crower or any other good manufacturer for rods.
