building 500hp 350 help me out!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2003, 08:36 PM
New Member
i am building a 350 for the drag its gonna be backed by a turbo 350 tranny and 456 gears its gonna be in a 1984 camaro so its gonna have a cage and everything so it will hold it!
thing is i don't wonna boost the 350 pure engine i want!
so far i got
350 bore .30 over
stock crank- shot peened-balanced
stock rods-shot peened-balanced also
pete jackson gear drive
12-1 flat top pistons
pro topline heads 220 64 cc heads 202 intake and 160 exhaust 3 angle valve job
dual tunnel ram 2 holly 600's or victor jr intake with holly 950
roller rockers
roller lifters
roller cam not sure what size
aluminum pulley set
electric water pump
will be ran on race gas!!
Old 09-21-2003, 08:41 PM
Jmark's Avatar
Re: building 500hp 350 help me out!!
Maybe, but only if the stock rods and crank don't break first. Trying to get 500 hp on a carb'd 350 will take some work. And the 350 tranny probably won't last long either.
Old 09-21-2003, 08:44 PM
New Member
well then i will buy new rods to while i am at it what you guys think i will make hp wise let me know i need info and some help on makeing that much hp!
anyone got any combos
Old 09-21-2003, 08:49 PM
Jmark's Avatar
Here is what it will take to make 500hp.
Old 09-21-2003, 08:51 PM
WV hillbilly
Last journal entry: PTL 220CC
com cams XR 294 is all the cam you need, peak power will come in @ 6500 peak torque will be @ 5000 I used sportsmanII's and came up with over 500hp and over 480ftlbs given the margin for error (im subtracting 47hp) that should put you right @ 500hp at 6500.....of course Im using desktop dyno, but it should be within 50hp or so I would think...
Old 09-21-2003, 08:56 PM
New Member
engine
thats a 383 stroker don't think a 350 can put out near 500hp??
whats the specs on that xr294 cam??
Old 09-22-2003, 02:44 AM
WV hillbilly
294/300 adv .540/.562 110/106 solid roller
Old 09-22-2003, 04:30 AM
New Member
2wld4u
thanx for the info!
Old 09-22-2003, 05:13 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I would use better rods at least. The stock crank will be okay if you keep RPM from getting out of hand, but stock rods......I would at least upgrade to a 5140 scat.
I would also go with the single carb for ease of tuning.
Also, ditch the gear drive for a good true roller chain set.
Chris
Old 09-22-2003, 05:53 AM
jamnut's Avatar
Rebuilding AGAIN!!!!
Aren't Pro Top-Line heads cast iron. With 12 to 1 comp you are going to want aluminum heads, cast iron and high compression don't make the best mix. You can run more timing with aluminum heads without getting detonation.
Also I'm with TurboS10 on the Forged crank thing. At least 4130 Forged and not a generic crank, Scat, Eagle or something like that. You should be alright with GM X rods ( pink rods ) at that horsepower. I wouldn't go with a regular cast rod though if you do go with cast rods at least have them Shot Peened. 12 to 1 comp is going to have pretty high cylinder pressures.
Old 09-22-2003, 09:25 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Just wandering how you got 12-1 with a flatop piston.
Troy
Old 09-22-2003, 09:33 AM
WV hillbilly
some of the pro topline heads come out with 50cc chambers, he has the same heads I have on my chevelle apparently..mine have 50cc chambers also...I think this option was for circle track racer's in some way because that's the only other place Ive seen these heads...
Old 09-22-2003, 10:54 AM
engineczar's Avatar
I was kind of wondering the same thing Troy. Flat tops with a 64cc head even with 0 deck only gets you about 10.5:1
BSE Racing Engines
Old 09-22-2003, 11:39 AM
TurboS10's Avatar
Wiki Edits: 2
Maybe we are dealing with one of those infamous magical mystery engines that only exist in the mind of the builder.
Chris
Old 09-22-2003, 11:41 AM
DragTour69XL's Avatar
Galaxie Man
Is this your first engine build?
