Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a blown 468 bbc [ questions]
Old 12-02-2006, 10:06 PM
Bad Rat's Avatar
Bad Rat Bad Rat is offline
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I am building a BBC Blower motor for my Anglia , I had the block bored 60 over making it a 468 ci, with flat top 8.5 CR forged pistons,, I am trying to narrow the choice of cams down,, and have been considering the Comp cams nitrus HP cams,,[ Full Roller hydraulic ] there are a couple of different grinds available, # 1 is the Part # CCA-11-414-8 with a intake duration of 242 and ex duration of 254, at .50 and lift of intake 566 int.575 ex.rpm range from 2400 to 6500 and #2 comp ,#CCA-11-411-8 duration int. 279 ex dur 294 lift int.537 ex 541, perf. range is 2000 to 6500 rpm,,,, both have a 113* lobe sep. just 400 RPM differance on performance rpm,, maybe someone has a better ideaa for a cam,, I would prefer it be a roller,,,
So what do some of you engine builders think would be best for street duty,, with maybe a blast on the strip ocasionally,, the car will probably weigh around 2000 #??? the blower is a B&M 425 mega charger,, with probably 6--9 # boost ,,, The heads are REC port open chamber cast iron, GM,, and the valves will all be new ,, with normal porting ANY IDEAS??? Thanks BILL
