Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a blown 468 bbc [ questions]
Old 12-03-2006, 01:11 PM
Bad Rat's Avatar
Bad Rat Bad Rat is offline
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Thanks auto nuerotic,, I will look into the suggestion,, I know there are blower spefic cams,, but I think the Comp cams [ listed] are considered blower spec also,, I am a little concerned about the heat also,, but will just have to deal with that if it pops up,, i have a custom built ron davis radiator, What are the specs on the cowler that you are using? I had a SBC with this B%M on it with a B&M blower cam,, and it had exactly the same specs as the edelbrock Performer RPM cam,, it worked great,,Thanks,, Bill
