Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a blown 468 bbc [ questions]
Old 12-08-2006, 11:49 AM
Bad Rat's Avatar
Bad Rat Bad Rat is offline
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Well I went with the comp 414 pro magnum nitrus cam,, along with the comp roller lifters,, I decided to use the stock oval port 781 heads, after reading a article about the flow rates compared to the rect port heads,, seems the oval port heads out flow the rect ports quite a bit after a little porting work, mush more suitable for street use,[ and MUCH less expensive] up to the 7K rpm range. I can always up grade to the rect, heads later,, save a few bucks for now anyway,,, I'll find the article and post it,,,,,,some good infromation,,,,,,,,,,,,,,,, thanks for all the suggestions,, Bill
LINK http://www.maliburacing.com/ovalvsrect.htm also read the article at the end called polishing a set of sneakers,,,,
