Building chassis from scatch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 11:06 PM
I'm building a chassis to fit a holden 253 small block and 9" diff and was looking at using 75 by 50 box for main section but not sure on what wall thickness will work. Any help would be great.
Old 01-06-2012, 12:04 AM
327NUT's Avatar
You mention a Holden and then 75 x 50 box section so I'm assuming you're in Australia ?? Depending on the horse power which may not be too much I think a 3/16 wall would be more that adequate with the properly placed cross members.
Old 01-06-2012, 10:47 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
3mm (0.1182") would be very close to 11 gauge (0.1196"). Although I never measured the thickness of an early Ford frame rail, it is said that Henry used 11 gauge for his production rails. 0.118" is also the N.H.R.A. minimum thickness for mild steel rollbars and rollcages.
75 x 50 x 3 should work, or if you need a little extra beef, 100 x 50 x 3.
Old 01-06-2012, 11:49 AM
You REALLY need to see this thread.... Building A Homemade C-cab !!!!!
Building a Willys pick up chassis bruce mckenzie Hotrodding Basics 173 09-19-2010 11:03 AM
Building a 60s style gasser/AFX chassis willys36@aol.com Suspension - Brakes - Steering 2 06-18-2008 10:18 AM
basic chassis building jessemax Hotrodding Basics 2 05-14-2006 11:50 AM
Chassis building for my '35 Pluymouth coupe 35plymouthcoupe General Rodding Tech 9 08-15-2005 08:34 AM
Chassis building americanLT1 Suspension - Brakes - Steering 14 07-26-2004 07:14 AM
