Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a Cheapy drag motor
Old 07-12-2008, 01:12 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
"cheap" = forget the roller cam. Forget the stroker crank.
+.060" 350 with flat top pistons. get the block "0 decked"
http://store.summitracing.com/partde...1&autoview=sku
This kit has 10-10 bearings and +.060 pistons.
resize stock GM 350rods with arp bolts.
stock GM 350 cast crank.
Summit Aluminum heads
Hand port matched vic Jr intake 750cfm carb
Isky #201547
solid flat tappet cam and isky lifters
Isky 547-A timing specs degree in the cam on a 102 intake C/L
Summit roller rockers
This is a simple, power, full cheap, bolt together dependable bracket motor.
max bang for the buck. The money you would have wasted on a retro roller cam+kit is much better spent on cylinder heads.
The money you saved on the stroker crank you can spend on a quality racing torque converter (9" 4000 stall)
4.10's short slick 4.56 tall slick
This motor is fine on 150-180hp spray if you run it on 100% 110-114 octane race gas and watch the spark timing. Open up the piston ring end gaps for nitrous. bigger is better.
Any more spray than this is not "cheap".
