Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - building a chevy 350, need some advice
Old 10-27-2002, 05:23 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
we build this as a basic budget performance motor; 350 block +.030 or .040 flat top hypereutectic pistons. resize stock rods with new aftermkt bolts, regrind crank,, new cam bearings, double roller timing set, hyd cam short duration up to 480 lift,high volume oil pump. then we take the heads mill them.010 new bronze liners, match intake ports to the gasket smooth upper port on exh, blend in bowls, three angle on the seat two on the valve,new springs to compliment the cam.this combined with a good dual plane intake and a set of headers will make reliable power that won't cost you your life savings,easy on parts and gas.
