Building a door dolly? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-05-2011, 02:52 PM
Actually Martin I used the dolly to hang the door first. I put the door on the dolly, put the wrench on the bolt, loosened it a little, adjusted the height, tighten the bolt and it was done. Minor adjustment during door fitment but always an easy one man job. I had manhandeled them before and this was a 100x better and not bad for something which was made in about 2hrs.
  #17 (permalink)
Old 10-09-2011, 11:18 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
update
Well, I got really po'ed at myself, and one thing I did was to remove the doors without help of any kind. Not something I want to do everyday, and I will have to have something like the dolly above to reattach them when I get to that point. Need to build something to roll them around the garage too.
Russ
  #18 (permalink)
Old 10-10-2011, 04:23 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
The ones like gow589's got would be nice if the upright post was made from an old bumper jack maybe.
  #19 (permalink)
Old 10-10-2011, 04:27 PM
Now that is an interesting idea.
Russ
  #20 (permalink)
Old 10-11-2011, 05:39 PM
I don't think you could move a door up or down a 1/16" with a bumper jack. I have never ad a problem moving the door in small increments. With the bolts snug, loosen, minor adjustment, tighten done.
  #21 (permalink)
Old 03-13-2012, 06:30 PM
e-tek's Avatar
www.E-tekRestorations.com
No offense, but you haven't done a lot of doors then. Often if they are hanging from the bolts and you loosen them without any support they will fall too far. It's also VERY hard to move doors up - at all or evenly - without some support under them. I've installed and adjusted MANY doors over 35 years in the biz - there are reasons people are making jacks and stands....
  #22 (permalink)
Old 03-13-2012, 07:46 PM
E-Tek, I too have been in the business for 35 years and I find that it is no big deal at all to move a door up. How have we done it all the years before these jacks or lifts existed? I have never worked at a shop in my life including my own where I was basically a one man show, never had anything but my body to lift a door, in fact got pretty good at putting them on, and hoods and trunks by myself.
I hear were you are coming from in that it could make it easier but it certainly isn't necessary.
  #23 (permalink)
Old 03-22-2012, 08:19 AM
deadbodyman's Avatar
Wiki Edits: 11
Jeez Pugs Now thats a great idea...I'm making a set...I've always done it myself ,doing a balancing act with a floor jack and I'm pretty good at doing it that way but its can be a mother at times...
Theres also something to be said about brians way (getting a helper) That way if you scratch the paint you can have someone to blame....
  #24 (permalink)
Old 03-22-2012, 09:18 AM
I am just a back yard hack, never been in the business.
By far the easiest I have ever hung doors is using an overhead crane.
Put a choker around the door so it hangs in a balanced upright position.
Fly it to the door opening, lower into place.
A few bumps of the control buttons to align and done, ready for final alignment. Total time per door maybe 3 minutes.
  #25 (permalink)
Old 03-22-2012, 06:47 PM
123pugsy's Avatar
Wiki Edits: 29
I like this idea as well.
I just happen to have an electric overhead winch attached to my hoist.
I'm building a 1926 four door sedan hot rod and i want to form an aluminum top chucksue Hotrodding Basics 4 08-20-2011 02:01 PM
Hammer and dolly set????? jimcar-9 Garage - Tools 8 09-26-2009 12:34 PM
Car Dolly??? JRork General Rodding Tech 3 09-17-2006 07:27 PM
advice on door frame building gahi General Rodding Tech 5 11-01-2004 07:35 AM
building door hinges spankthru Body - Exterior 1 05-12-2003 07:05 AM
