building a fiberglass dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2006, 10:02 AM
raidmagic's Avatar
Last journal entry: Engine going back in the Hudson.
I am making my own dash panel for my gauges and in the process am changing the shape of that area of my dash.
What I have done so far is cut a thin piece of luann then made a jig to hold it in shape and covered it with fiberglass resin. After that I layed the front and back of it with the woven cloth and resined that. I think that I want to add more cloth and resin to make it stronger but what I need to know is should I sand the current resin to make a better bond with the new stuff and which should I be using the woven mat or the fiber mat? Thanks
Old 04-27-2006, 02:39 PM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
I am in the process of making a 32 fiberglass rad shell fit the Walker that is already installed in my 29 Tudor. I had to shorten it and cut it in four places to make it wider. Anyway I sanded the areas where the new layers of glass were to be attached to the old. The sanding scuffs the area and as I had read at one time makes for a better hold.
Old 04-27-2006, 08:55 PM
raidmagic's Avatar
Which mat are you using, the woven or the other mat?
Old 04-28-2006, 10:05 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Definitions
the woven style is called cloth and the other stuff is called Mat..that being said I would use the mat to lay up a dash as it conforms better to odd shapes...if you carry on with your layup there is no need to sand between layers..if it has been setting around for a while like on a repair then sanding with an 80 grit paper will give you some tooth for adhesion..
Sam
Old 04-28-2006, 10:47 AM
raidmagic's Avatar
Thanks it has sat for a few days so I'll hit it with some sandpaper before adding to it.
fiberglass door panels, dash, center console, sub enclosure, amp rack liftedbowtie Interior 74 09-15-2011 12:36 AM
Fiberglass Tutorial kristkustoms Interior 59 04-13-2009 08:10 AM
Mounting fiberglass dash mrmagoo187 Interior 24 11-04-2005 06:43 PM
Fiberglass Dash Help birdman891 Interior 5 04-04-2005 07:29 PM
Fiberglass dash Weimer Hotrodders' Lounge 5 09-27-2004 02:56 AM
