building a fiberglass plug then mold - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 07:24 PM
I have RC drag boat hull made of styrene. I want to pull a plug and then make a mold. what type of foam or other product can I use to fill the hull and cap to pull a plug ?
Old 03-04-2013, 09:07 AM
ogre's Avatar
the 'Duracell Project'
i'd start at fiberglassforums.com
the plug and mold can be made out of anything; wood, plaster of paris, sheetrock mud, sheet foam, can foam
the level of finish on the mold will dictate what finish you'll get on the finished product.
Old 03-04-2013, 10:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If it is sytrene you have a real issue as styrene melts when regular fiberglass products are used on it..I would make a mold from plaster of paris from the existing and then make the new hull from that..
Sam
Old 03-04-2013, 08:05 PM
Sam
ok thanks. I know styrene will melt with finishing resin. Thats why I wanted to know what I could pour into the hull to pull a plug. With the plug made then I would start building the mold
Old 03-08-2013, 09:05 AM
use epoxy resins, buy a gallon from ebay, it is useful for many things. Wax the outside of the hull,add flanging and then lay up your mold. Search around on you tube lots to see there. been done before, fun and satisfying project.
Old 03-08-2013, 10:11 AM
Hey! Don't forget, Von Dutch used wadded up newspaper and plaster of paris.
BB
mirror image fiberglass mold daoldbuick Body - Exterior 1 10-15-2008 10:46 AM
How to mold fiberglass? Slimpikins Body - Exterior 12 05-19-2008 02:08 PM
help making a fiberglass mold adam120674 Body - Exterior 2 06-14-2007 10:20 PM
foam for fiberglass mold stea Interior 7 08-17-2006 05:25 PM
Smoothing out a plug to make a composite mold? mkehler Interior 5 10-08-2005 08:14 AM
