Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building First Engine
Old 09-23-2008, 03:12 PM
eatonde eatonde is offline
short block
yea, what he said. It all depends on how well you trully know the block and rotating assembly to decide whether its worth using. And as i said before i personally would go with flat top pistons for performance either way, unless you got some good 58-60cc heads to get your CR up. If you got the money go with forge if you change them, that will leave the nitrous option open for you down the road.
