Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - building a gas powered air compressor
Old 07-05-2008, 02:17 AM
47dodge's Avatar
47dodge 47dodge is offline
Last journal entry: 1947 dodge
Thanks for your help. I think I found the parts I need at Surplus Center. If these are the correct parts I will order them with my next check. unloader valve, pressure relief valve, back-flow valve, and on ebay the idle kick-down control. I used their picture from the unloader valve and changed some things. Do I put a T in where the red circle is between the check valve and the tank to get my air?
