Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - building a gas powered air compressor
Old 07-05-2008, 05:33 PM
oldred oldred is offline
Originally Posted by oldschoolrods
Not to threadjack but has any one ever built one of these for stationary use, ie installed in a home shop. I can see some draw backs but I would think it could be done for a comparable price to a regular electric motor driven unit. Any thoughts??
Yes it would absolutely break you up in fuel costs!
They are OK for occasional use or for something like 47 is talking about but not for shop use. To equal a 5 HP (true 5 HP, not "peak") compressor would take at least a 10 HP gas engine and to get any real efficiency out of it you would need a two stage pump so the costs to build it would be more than a good electric compressor long before you would finish it unless you had a lot of the parts lying around already. When you figure just how much time a shop compressor runs and gas costing over 4 bucks a gallon the costs to run it would be staggering.
