Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - building a gas powered air compressor
Old 07-05-2008, 09:11 PM
oldschoolrods's Avatar
oldschoolrods oldschoolrods is offline
Last journal entry: Engine Compartment
Originally Posted by oldred
Yes it would absolutely break you up in fuel costs!
They are OK for occasional use or for something like 47 is talking about but not for shop use. To equal a 5 HP (true 5 HP, not "peak") compressor would take at least a 10 HP gas engine and to get any real efficiency out of it you would need a two stage pump so the costs to build it would be more than a good electric compressor long before you would finish it unless you had a lot of the parts lying around already. When you figure just how much time a shop compressor runs and gas costing over 4 bucks a gallon the costs to run it would be staggering.
Yeah thats a good point, electric = 13 cents per kwh, gas = $4 gallon if you figure 5 HP is rougly 3.7kW the cost of the electric compressor for 1 hour is about 50 cents, gas would be atleast $4 on a good day. so yeah I guess this is not a great alternative.
