A little Look at what's been going on at the bat cave...
Centerline... I know these pictures will make you roll over.. Centerline.. It won't be staying that color.. Haven't been doing to much on the C-Cab lately.... But still Pulling it a long.. |
one more..
Had to see what she would look like with a motor... And for the ones that think it's so ''HEAVY'' I didn't even have to add any air to the tires when I set the motor and trans in... |
I seen it... thanks !!!!
eye
what a great job looks the duck's nuts !!!!
MAN !!!!! Where have you been hiding at ???? Good to hear from you... I have to say this.... I don't have a clue what you are saying sometimes... The words y'all use,, Well !!! us coon a***'s don't usually hear them saying.. |
Willys is at that stage seats in and steering done I am happy ?????
What I do on all of mine is,,, I figure out what I need to cut off,, Put tape around the bottom, And cut it off with a cut off wheel,, Then I drill out the two little dimples on the side's that hold's the Bushing in at the bottom,, Now.. once you do all this, And you have the bottom piece in your hand with the bushing ,, Place it into a vise,,, I then carefully knock out the bushing,, (it's easier to knock it out once the bottom piece is cut off the column) Then put it into the other good part...(column) Knock it in carefully.. Now.. take a center punch and add a couple of dimples to hold the bushing in.. Just try not to move the shaft to much.... I have done this to a lot of column's like this... Never had a problem... Just don't try to tilt it without the bushing in it..I never take the column apart when I do one.. Or you can just take everything a part.. Truck look's GREAT !!!!! Last edited by NEW INTERIORS; 08-06-2011 at 08:49 AM. |
Here are some links to shorting a F/R shaft
http://www.trifive.com/forums/archiv...p/t-56710.html http://www.network54.com/Forum/82899...umn+shortening Last edited by Bad Rat; 08-06-2011 at 11:09 AM. |
Thanks for the links Bill....good info
(**** happens) and I needed to replace the whole turn switch mechanism $50 from them but I am not able to get onto there shop without pass word summit has them so I am back on track did it in the lathe and saw and back together easy peasy thanks to you all you sure are a lot of help to us down under, any time I need to know anything this my first port of call,
Thanks... I'm just your everyday hotrodder.. I might take you up on that one day... I would love to see your Country... |
I just made my first video... Not sure if it's going to work are not.. But here goes nothing.. I hope everyone will enjoy..
http://www.youtube.com/user/newinteriors?feature=mhee Last edited by NEW INTERIORS; 08-12-2011 at 03:43 PM. |
Great video Randy
Cole |
| Homemade dragster | rednek_racin | General Rodding Tech | 1 | 06-02-2009 07:11 PM |
| Homemade Rod | speedydeedy | Hotrodders' Lounge | 110 | 01-30-2008 09:13 PM |
| homemade 302 boss | claycountystang | Engine | 42 | 11-20-2006 12:41 AM |
| Homemade Fan Shroud? | JohnTN | Engine | 4 | 07-18-2005 05:08 PM |
| Homemade oilpan? | alex_0227 | Engine | 5 | 03-27-2005 06:35 PM |
