Building A Homemade C-cab !!!!! - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #61 (permalink)
Old 02-06-2011, 06:32 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Originally Posted by matts37chev
its always easier when there is a fire for a project in your belly!
and it looks like you are on fire, for sure!
looks great, keep it up
Thanks..
  #62 (permalink)
Old 02-06-2011, 07:39 PM
cboy's Avatar
Last journal entry: Finished
Originally Posted by NEW INTERIORS
..I wish I was better at explaining what I'm posting..
Those great pictures do about all the talking you need.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
  #63 (permalink)
Old 02-07-2011, 10:46 AM
New pictures..
ID:	52479   Click image for larger version
ID:	52480   Click image for larger version
ID:	52481   Click image for larger version
ID:	52482   Click image for larger version
  #64 (permalink)
Old 02-07-2011, 10:48 AM
few more..
ID:	52484   Click image for larger version
ID:	52485   Click image for larger version
ID:	52486   Click image for larger version
  #65 (permalink)
Old 02-07-2011, 12:45 PM
boatbob2
Hi Randy......
Hi,looking very good,no grass growing under your feet !!! though im not a big fan of tie-rods in front...
  #66 (permalink)
Old 02-07-2011, 01:02 PM
Wiki Edits: 31
looking pretty good..
did you set the perch 3* back for Camber like Speedway suggests? When I put my frame togther ( which will be replaced/ rebuilt longer and better as soon as I get the chance ) I did it 3* back, but after searching some. I found some say that it's not nessasary... I will get the drop perch for the next frame
  #67 (permalink)
Old 02-07-2011, 02:06 PM
deckofficer's Avatar
www.tbuckets.lefora.com/
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
Randy,
To say you move right along with a build project would be the understatement of the year. On a "T bucket only" forum I have watched the progress on a really fine build carry on for 17 years. I know you are firmly planted here, being part of the donor pool to defend free speech (my hat is off to you for this), but any chance of sharing this most stunning build rate with the T-bucket group at http://tbuckets.lefora.com/ . I know you are a busy guy, time is valuable, but I can promise you nobody on that site as witnessed build progress like the lucky folks here. With those hours you put in, and being from La, are you a offshore oil patch worker?
Bob
  #68 (permalink)
Old 02-07-2011, 02:30 PM
It will need a longer tie rod moving the pivot points closer to the wheel but with that all will be good in the akerman angle dept.
  #69 (permalink)
Old 02-07-2011, 05:28 PM
No Mr Bob... I don't.. You never no when your day will come... You might not be here tomorrow.. So I try not to put anything off till tomorrow..
did you set the perch 3* back for Camber like Speedway suggests? When I put my frame together ( which will be replaced/ rebuilt longer and better as soon as I get the chance ) I did it 3* back, but after searching some. I found some say that it's not necessary... I will get the drop perch for the next frame
Matt.. It depends on what axle you go with... By the book it should be set around 3* up.. But I have set them up at right at level, with no problems.. I use the axle with the bat wings... The spring is bolted through the side.. On some axles the spring is bolted through the top of the axle... The one that goes through the side of the bat wing can be set at any angle you want.. But I like to set it level.. The axle move's in a arch.. But with the long arms.. It's so little movement up and down, don't really matter.. Some WILL tell you different..
  #70 (permalink)
Old 02-07-2011, 05:35 PM
Originally Posted by deckofficer
Randy,
Bob
Mr Bob thanks for the web site.. I will try, But sometimes it's hard to do just one site... I never worked in the oil field.. But I did help build the boats that supply the offshore.. I worked in the shipyards pretty much my whole life... Had some other trades also..
You know the old saying: Jack of all trades, Master of none..
  #71 (permalink)
Old 02-07-2011, 06:01 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Just found this thread.
Looking good Randy!
  #72 (permalink)
Old 02-07-2011, 07:16 PM
OLNOLAN's Avatar
Get With It
Hey Man, Thats the beauty of working for yourself. Here you have people thinking you're Speedy Gonzales. Working in the shipyard, if thats all you had cut and welded in 4 days, you would probably get run off. Ha Ha, Living the dream Man. I'm enjoying this, now git yo butt back to work, HaHa Nolan
  #73 (permalink)
Old 02-07-2011, 07:39 PM
What kills me is this "truck" (it isn't one yet ) didn't exist a few weeks ago. This is one thing I love about fabricating, making something that didn't exist the day before. How gratifying this must be for Randy to create an entire truck that didn't exist!
  #74 (permalink)
Old 02-07-2011, 09:02 PM
Looking good Randy!
Thanks..
Nolan.. I was always pushed to work like a robot my whole life.. I think it stuck with me...
  #75 (permalink)
35terraplane's Avatar
homemade c-cab
Randy I think I said on my 1st post to you that I knew you were nobody new to building cars, And this one sure doesn't change anything, looks super, nice job.
Bob
Homemade dragster rednek_racin General Rodding Tech 1 06-02-2009 07:11 PM
Homemade Rod speedydeedy Hotrodders' Lounge 110 01-30-2008 09:13 PM
homemade 302 boss claycountystang Engine 42 11-20-2006 12:41 AM
Homemade Fan Shroud? JohnTN Engine 4 07-18-2005 05:08 PM
Homemade oilpan? alex_0227 Engine 5 03-27-2005 06:35 PM
