Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - building ls 6.0 truck engine
Old 09-11-2011, 03:51 AM
4dawy 4dawy is offline
hi boss
efi without power add
my goal is biuld it my self and get about 500 hp
i will use the orignal strocker and change the piston to flat one
and i will look to L92 heads (is the camaro 2010 heads are same ?)
i expect the cam more than 0.580 lift
the injectors will be change to 40l
with fast intake manifold ,headers,some aluminum parts,3.73 rear end
can you help me to make 11 compression with l92 heads
what is the good piston for that
