building ls 6.0 truck engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2011, 02:49 AM
hii guys
i am from saudi arabia
i want to build a 2002 6.0 l truck engine to drop it in my 2000 camaro
but i want about 550 hp in the engine without using of a strocker kits
can anyone help me ?
Old 09-09-2011, 03:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 4dawy
hii guys
Carb or EFI? You willing to use a Procharger, or turbo? Nitrous? What kind of budget?
You can convert to a carb using the Edelbrock p/n 2908 Vic Jr. (includes ignition box), get aftermarket or L92 heads, toss a big cam in it along w/headers and exhaust system and get the numbers you want. It will take a good bit of work to get that kind of HP hooked up and the rear end, tranny, and suspension will all need upgrades. If it were me, I'd be caging it.
You might want to take a look at some of the forums that cater to the LS engines.
Old 09-11-2011, 03:51 AM
hi boss
efi without power add
my goal is biuld it my self and get about 500 hp
i will use the orignal strocker and change the piston to flat one
and i will look to L92 heads (is the camaro 2010 heads are same ?)
i expect the cam more than 0.580 lift
the injectors will be change to 40l
with fast intake manifold ,headers,some aluminum parts,3.73 rear end
ــــــــــــــــــــــــــ
can you help me to make 11 compression with l92 heads
what is the good piston for that
Building Drag Truck General Martok General Rodding Tech 2 06-20-2011 12:31 AM
building another truck IROC100 Hotrodders' Lounge 2 02-16-2005 03:14 PM
Building an Engine or Building a Combination. . . Cstraub Engine 3 10-13-2004 04:39 PM
building my first truck kdh67 Introduce Yourself 3 07-17-2004 10:17 AM
Building a TBI truck engine NAIRB Engine 5 03-05-2003 09:30 PM
