The High Dollar paint booths the big boys use are down drafts. Makes sence because the spray mist is heavier than air and wants to go down and the down draft helps it. If you are exhausting high, the booth tends to fog up and you tend to have a bigger overspray problem. There are some super air conditioner filters available on the market. Just read the label and get the smallest micron available (usually can tell by the highest price tag)
Trees |
Locate the fan or fans for incoming air where they will pick up the least amount of dust. Could be high or low depending on your set up. In the booth I'm using this weekend (which is smaller than the one in the pictures) I'm using one fan on high to supply air and another fan on the opposite side on medium to pull air out. Both are sitting on the floor.
All you need is enough pressure inside to keep the plastic walls from moving freely. The side benefit is that it also keeps the dust down. You'll never get rid of all the dust painting in your garage but if you plan to color sand and buff, any dust nibs you get will sand out anyway. Centerline http://www.hotrodsandhemis.com |
Nope, it could not have worked better. Everything stayed inside the booth if that is what you mean. As far as the above arrangment, I am not too sure. From what I have read the downdraft booths the pros use are the best so it made sense to me to do it the way I did. I had no problems with dust or overspray settling after the final coat. I left the fan running for about an hour untill the paint was past the tack point. This varies with different paint, but you do want to leave the fan running to keep things moving so they do not settle in the paint. Dust will find its way in on even the best booth, and some nib sanding and buffing is almost inevitable to those of use with modest budgets. I will say that I had no bugs or large contaminants, and Everything sanded out. I added a photo in my album so you can see. There is not much to it. The fan is under the big door in the back. Chris Last edited by TurboS10; 11-01-2003 at 07:59 AM. |
this is what i did in my garage..
cover all the walls and ceiling with a light thin plastic and make it as tight as possible to eliminate the plastic from blowing with the air movement from the fan, try to have the garage as empty as possible, sweep and blow it out really well the night before. i have the fresh air inlets at the bottom of the front garage door and there are 4 big filters all the way across the bottom, at the back of the garage there is a door leading outside into the back yard. i bought a cheap door from lowes and cut two holes in it and braced it very well and mounted two small attic fans in the doors, when ever i plan on painting, i pull the pins out of the regular door take it off and hang the new door with the fans. i also fabricated a box that goes in front and behind the fans that houses 5 filters to catch the overspray. three filters before the fan and two after. this is pretty extravagent for the one time paintjob, but i paint in my garage on a regular basis and i have never had fumes go into my home and i have never had overspray on any vehicles outside. i also wet the floor and all the filters before i start spraying and again before i start clearing. i have turned out some very nice paintwork in my garage and have never had any complaints from any of my neighbors. |
PrimeMover , I'm in the same situation as you . I also plan on doing the same thing this spring . I live in a lite Industrial zone but still have the DEQ thing. this thread has given me several good ideas (Thanks All ) . Moving here from North Carolina last year I didn't have these problems there. We'll see how it goes.
I am painting the car with JD Blitz Black. If I have to wet sand it won't get shiny will it? I want that satin black look. |
My shop has a dedicated paint booth with ceiling and wall lights, water drain in the floor for wash down and wet sanding. I use a 3000cfm swamp cooler with commercial filter medium wrapped around it and rectangular holes cut in the aluminum garage door and wall on either side, again with commercial filter material. works great!
Wet sand with 400, then 600 then 1000 and you will end up with the suede look you want. http://hotrodders.com/showthread.php?s=&threadid=27167 Last edited by willys36@aol.com; 11-03-2003 at 07:34 AM. |
Ranchero - welcome to Oregon! <cough>
The fifteenth of this month, I'll be in Eugene to watch the Ducks take on the Beavers in the Civil War game. You've got mail |
As 302/Z28 said, those cheapie window fans are induction motors without brushes, no sparks BUT there is when you turn it on & off in the switch! Be careful.
I've done some spray painting, mostly in indutrial applications for electrical cabinets, no too much automotive. 2 things I didn't see mentioned that I think are important to point out. Most modern automotive paints are toxic and can be absorbed through the skin. The other thing, GROUND EVERYTHING! otherwise if the car has a different charge, it'll attract particles in the air. |
| Recent Garage - Tools posts with photos |
