We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 10-31-2003, 07:59 AM
thrown_hammer's Avatar
thrown_hammer thrown_hammer is offline
Different kind of import
Building my own one time use paint booth.
Any advice appreciated. Here is my plan and if anyone can help me improve it I would be grateful. I am painting in the spring so i have time. This is going to take place in my two car garage.
Heavy plastic across rafters and hanging down to floor for the "walls". Duct taping the corners and using 2X4's at the base. Leaving the garage door open about a foot and cutting an intake hole in the plastic with a furnace filter on both sides of the hole. Cutting a hole on the other end high in a window frame for exhaust. placing a filter on the inside and a sparkless fan on the outside to draw air out. compressor will be outside garage. I will mist the floor with water. Also some halogen lighting outside the booth shining thru the plastic for light. Anything else?
Using JD Bltz Black paint in a Brinks gun.
Old 10-31-2003, 08:04 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
willys36@aol.com's barnstar
Wiki editor
Last wiki edit: Fiberglassing
Wiki Edits: 20
Sounds good. Only problem I envision is having too much exhaust for the inlet capacity and sucking the walls in. If that isn't a problem, should work fine. I know of several people that produced world class home paint jobs with that type of temporary booth.
TurboS10's Avatar
TurboS10 TurboS10 is offline
DIY Everything
Sounds good. I did my S10 in a very similiar booth. Good Luck.
Chris
Old 10-31-2003, 08:11 AM
Cool! I could always cut two intake holes...
Old 10-31-2003, 08:24 AM
Wiki editor
Wiki Edits: 20
Don't buy problems B4 they happen. Try it with one first and do the second only if there is a problem. Two inlets spaced apart may give better air flow and vent fumes better. Anyway, try it with one first.
Old 10-31-2003, 09:16 AM
TurboS10's Avatar
DIY Everything
I used a 2500 cfm attic exhaust fan and a 3x4 ft. intake area up high on the opposite side of the booth from the fan. While the fan probably was an explosion hazzard, I am still here. It worked very well having the intake up high and the fan down low. It pulled the overspray right to the floor.
Chris
Old 10-31-2003, 09:28 AM
daimon1054's Avatar
daimon1054 daimon1054 is offline
To me still air in and area where you cannot filter all of the air is better than moving air. I would be worried about what contaminants you are moving around. A home air conditioner filter does nothing for small stuff and you IMO will be bringing a lot of pollen and small dust into your area. I would focus on making sure I had good air to breath and keeping the air in the room still. Let the dust would settle to the ground and your dry car (tack it off) and not on your wet paint.
Again I am not an expert here so feel free to dispute me!
Old 10-31-2003, 09:42 AM
I was told to have the intake low and the exhaust high to keep the over spray from setteling on the car. But then again thats why I am here.
Chris, Did you have any overspray issues?
Old 10-31-2003, 09:49 AM
Wiki editor
Wiki Edits: 20
A key I have found is to not shut off the fan until the paint has dried to the point that dust won't attach. Shutting off too soon allows stuff to settle.
Old 10-31-2003, 10:18 AM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
Thats almost exactly how I painted my coupe. Matter of fact I'll be painting the cab of my truck tomorrow in the same booth.
Here's the booth, and the results.
Centerline
http://www.hotrodsandhemis.com
Old 10-31-2003, 12:05 PM
First of all WOW!
Now are the fans up top the exhaust fans? If my car looks half that good when I am done I will consider it a success.
Old 10-31-2003, 12:08 PM
Centerline's Avatar
HotRodsAndHemis.com
Wiki editor
Wiki Edits: 38
Actually the fans up top are incoming air. I use one fan for exhaust so it winds up being a positive pressure booth.
Centerline
Old 10-31-2003, 12:14 PM
Are they just box fans or are they sparkless fans? I am a little concerned about blowing the garage off the side of my house!
Old 10-31-2003, 12:23 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
If they are forcing air into the garage, that lessens the chance of explosion, as they are pulling fresh air through the fans. Most household box fans, at least the ones I have come in contact with have fractional horsepower induction motors that have no brushes.
Vince
Old 10-31-2003, 01:00 PM
So I should put the fan up high for intake and the exhaust vent low right?
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
