Building my own T-10 linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 11:31 AM
bonuts's Avatar
Got Ouzo for touzo
Putting a Richmond super T-10 in my s-10 that was in my circle track race car. I'm planning on just shortening the existing shifter linkage as the shifter was set back 8" in the race car and it was a nice tight setup with heim joints. I have got a factory mount for the hurst super shifter and it looks like I can just shorten these rods. I don't want to buy the whole hurst install kit just for the factory linkage.
I have shifted the trans on the bench and all forward gears work nice but its a real PITA to get into reverse. Hoping this is just because its on the bench? No linkage interferes with other linkage or anything. Any ideas, or has anybody built their own linkage?
bonuts
Old 05-27-2013, 09:23 AM
I always build make my own linkage from aluminum tube and heims. The al tube can be cut to length and tappped with 3/8 NF left and right hand threads. I get the tube and heims from McMaster-Carr.
Old 05-27-2013, 10:24 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I think you may need to have the shifter clamped in a vise for testing on the bench..at least that was the way for me..check clearances and alignment of the shifter pins that way so you can make it work smooth..
Sam
Old 05-28-2013, 08:16 AM
S10xGN's Avatar
Gotta love a turbo!
Got a part number for that tubing? I've looked all over the 'net and all I can find with the right ID is too big or small on the OD...
Russ
Old 05-28-2013, 08:22 AM
Wiki Edits: 3
You will have to call Mcmaster Carr and get the correct terminolgy to find the part on the website. they are helpful in that area..
Sam
Old 05-28-2013, 08:44 AM
bonuts's Avatar
Got Ouzo for touzo
No idea what the part number is but I have seen the shifter rods sold in longer lengths pre threaded in Lefthanders catalog. I shortened the ones I already had. Still haven't got this thing to go into reverse nicely though.
bonuts
Old 05-29-2013, 09:17 AM
S10xGN's Avatar
Gotta love a turbo!
I bought some premade shift rods from Speedway, but it's really thin-walled. I ended up buying some 3/4" solid rod stock that I bored in my lathe and then tapped both ends. A lot of work, especially for those without a lathe. Here's a pic, you can see the difference between the anodized but thin Speedway rods and my 3/4" OD reverse rod.
Russ
Linkage 58darlene Engine 0 07-31-2010 04:23 PM
Help Me get my Linkage right! TorkMonster400 Engine 2 08-24-2009 05:39 AM
Linkage campy Engine 3 01-12-2008 04:14 PM
Linkage. Good Frosty Engine 3 04-03-2006 06:13 PM
Building an Engine or Building a Combination. . . Cstraub Engine 3 10-13-2004 03:39 PM
