Building a "new" school project - licensing/inspection question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 08:56 PM
Drop and Drag It
Hey there. So I am building a 2000 Toyota Tacoma 2wd std. cab. I plan to have it on air suspesnsion, fully shaved and painted. I was planning to put a 4cyl back into this truck cuz i got it without an engine, tranny, ecu, and some other lil electrical things. I figured it would be cooler and easier (probably not) to just go all out by throwing a 350 in it and doing a custom dash/gauges.
I was wondering if running a carb'd 350 and not having to worry about all that wiring crap (tell me if I am missing anything, i'm a noob at engines) that I won't have to worry about having to have what is missing in my truck, cuz I don't know exactly what engine components it had.
My main thing is, what do I do about inspection with the State Patrol and emissions? how do all the hot rodders drive their cars around and get away with it? Other than a special permit I am guessing? I live in the state of WA if anyone could help me?
So mainly, my main question is, can I get my truck passed and inspected with a 350 in it from our state patrol? Again I am in WA state. I tried looking on their website for info but I had no idea where to start. Would it be helpful calling them and talking to them about the guidelines?
I also tried searching for this question and i found one that was kind of like the one I am asking but didn't see much hope in that thread. Any help would be much appreciated, thanks!
Old 02-28-2006, 09:01 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Not 100% sure on your state but in most, the year of the engine does not matter, it is the year of the vehicle, so your 2000 would be applicable to all emissions stuff for that year.
Old 02-28-2006, 09:03 PM
Drop and Drag It
So are you saying that as long as it passes emissions, I am ok? or no?
Old 02-28-2006, 09:05 PM
Drop and Drag It
also I heard from 96 and up, or it was 98 and up vehicles, they don't have to put that thingy into your tailpipe to test smog, but instead just plug something into something under your dash? ugh this stuff makes me confused. I just want to build my ride how I want it!
Old 02-28-2006, 09:28 PM
I believe it is 96 and up they use the OBD-II diagnostic system for emissions test.
Old 02-28-2006, 10:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Check your local regs as there are certain areas subject to emissions inspcetions and others are not..Dept of ecology runs that not the state patrol..so you need to look there for info..
OMT
Old 03-01-2006, 12:00 AM
Drop and Drag It
well poopy day I say. I know in the area I am in, emissions is required. There are counties that get away with no emissions but I don't want to send my title to a place in that county. Anywho, I think I am gonna go with my stock motor, cuz I want to license this thing AND drive it, I don't want a trailer queen thanks for the help anyways guys! I'll stick around still!
Old 03-01-2006, 12:26 AM
Wiki Edits: 3
Did some checking
If your vehicle is over 25 years old you will not likely need to have emissions tested...sooo find a pre 84 car or truck to build and you may be out of the woods..At least what I read here This Place
OMT
Old 03-01-2006, 01:46 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
personally, i would recommend the supra / is300 engine, the 2JZGE
in the supra they came NA and turbo, in the lexus is300 they came NA
in both cases they are available with either an auto, or a manual tranny
this takes care of a few things:
1) its Toyota in Toyota, meaning it will get less questions during inspection
2) it follows the main rule of engine swaps, that teh engine has to be same year or newer then the chassis
3) the vehicle will pass all needed smog tests, because the engine was designed to comply with the laws set forth for the truck you have
it also leaves you with a HUGE aftermarket support, and you can upgrade the truck to be as powerful as you want .... 2000hp has been done with upgraded versions of this engine
us tuner guys get away with engine swaps for a number of reasons, and theses are the reasons in NY
1) the cops dont check under the hood, ive never ben pulled over and had a cop ask to see my engine
2) ive never had a cop ask if i had a converter on the car
3) no inspection shop bothers to tap on teh converter to make sure its not hallow
4) its possible to modify a cars ECU to the point that even if it knows somethings wrong, it wrong report it, meaning in some cases we can remove the second O2 sensor and teh programing that goes with it, and the dash will never show a check engine light
5) its possible to trick an ecu into thinking the cars exhaust is "normal" using o2 sensor sims
it really comes down to a matter of "anything you can do i can do better" ... they can legislate anything they want, but when you build 100,000 of a certain model car, there aer going to be 10,000 people working in their garages to reverse engineer anything thats been done ....
Old 03-01-2006, 07:06 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
In general, for cars requiring inspections (usually meaning less than 20-25 years old, depending on state), you can change engines but it has to be the year of the body or newer. Some states don't mind if it's a different manufacturer, but as mentioned, same manufacturer will get less eyebrows raised (they don't look as hard). Regardless of manufacturer, the engine will have to have ALL emissions equipment that it came with the year of manufacture and pass all emissions for that year. So if you put a 2004 Chevy crate motor in it would have to pass all emissions for a similar vehicle -- a Chevy pickup in this case. That's important -- trucks have a little less stringent requirements than cars. In some states they will ask waht the engine came from and use that as the basis for testing though. So if you put a 2001 Chevy Caprice engine in they'd test it to car standards, not truck.
But for the final word, contact the local DMV and/or testing station. They will be able to advicse you. I'd go to the station that will be testing the vehicle. They'll remember you, and as long as you are cordial and make it obvious you want to do things to their standards, they should be helpful and maybe a little less strict when you do come in.
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 05:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 05:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 05:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 05:53 PM
New Project - question about reproductions element Body - Exterior 5 04-15-2003 09:09 AM
