Building a performance muffler - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 10:54 AM
Blackdog's Avatar
I posted this on several motorcycle web sites and no one can help so I'm turning to the experts here.
I have a new 2009 Buell XB12XT. I plan on installing the race ecm sometime soon. I'll install the race muffler also when it becomes available. In the mean time I bought a near new extra muffler to mod. My goal is to have a better sounding bike without excessive noise. This is what I started with.
I first cut it apart and remover the 3 pipes and bulkheads.
I'll leave the interactive valve in place to give the muffler a stock appearance. The valve it is fully open at idle and at high power. It's closed mid range to increase torque. When it's close it routs the exhaust trough the smaller pipe to increase back pressure. The valve will still be there but will not really do anything as the original guts are gone.
The problem is it's too quite, it sounds like a sewing machine. What I want is a good free flowing exhaust that's not too loud.
I'm installing 3 baffles, the 2" holes will be staggered. 2 will be welded at the jack points and one in the middle.
I have a lot of hot rod experience and I'm kind of copying a Flowmaster 3 chamber muffler, not too loud and not too quite. Before I weld everything up, I'd like to know if I'm on track. Any suggestions?
Old 06-20-2010, 03:34 PM
airboat's Avatar
I think you are on the right track! I have built my own using design details from Fowmaster and other manufacturers. I used perforated steel and sheet metal for baffles, had one chamber pass through like Flowmaster. I think it worked great even if I don't know the CFM's or DB's. Sounds great IMO, a little louder than I expected but not as loud as many others. Sorry I didn't take any inside pics..
This one is for my 350 Porsche, 3" in and dual 2 1/4" out
Old 06-20-2010, 04:27 PM
Blackdog's Avatar
Thanks airboat. How many chambers did yours have? Did you make your own perforated sheet metal?
The inlet is 2" dia so I'm using one 2" hole in each baffle. I'll have 3 (holes staggered) baffles so I guess you could call it a 4 chamber.
I need to study a few cut-away views if I can find some.
Old 06-20-2010, 05:49 PM
airboat's Avatar
I built an inlet chamber, a chamber that's ported to the inlet with 2, 2 1/2" pipes passing through and then the last chamber. I have angled and V shaped baffles here and there made out of the sheet metal and perforated steel.
I purchased my sheet metal and perforated steel from " Metal Supermarkets" locally www.metalsupermarkets.com for about $1.50/ Lb and they have many choices for size of hole and gauge.
I just looked around at performance muffler company's websites for ideas.
Building a performance muffler Blackdog Engine 4 06-22-2010 09:22 PM
Performance Muffler Choices? A-BodyFan Engine 8 06-26-2006 08:58 AM
Building a muffler TurboS10 Hotrodders' Lounge 15 03-24-2004 05:09 PM
exhaust system length affect performance? smlblcks10 Engine 10 02-19-2004 05:40 PM
Auto Performance Business Venture Plan Opinions(long read) TurboS10 Hotrodders' Lounge 17 12-01-2003 10:33 PM
