Building a rack & pinion set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 10:29 AM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Has anyone built their own rack & pinion set up? I'm talking about having the rack and fabricating the brackets around it. What would be involved in a project like this. I know Fatman's has a kit for the mid 50's fords and you supply a rack from a 90's Cavalier. The brackets don't look all that complicated. I attached a picture of the kit. I need to get rid of my 605 box. Wurthit Designs is in the process of building a kit for 58-60 T-Birds but I don't think it will be ready anytime soon. I am desperate for a good steering system.
Thanks
Old 08-31-2006, 11:06 AM
astroracer's Avatar
Read the article I wrote on the crankshaft coalition site.
http://crankshaftcoalition.com/wiki/...ing%22_to_Rack
There are a lot of things this "swap" needs to take into consideration to work well. If it is not designed correctly you will not be pleased with the results....
Mark
Old 08-31-2006, 11:27 AM
aka Duke of URL
I just cannot get used to using ...{shudder} BOWTIE PARTS {shudder} on a genuine.
There was an attempt a few years ago of fitting a front steer rack (TAURUS) but it had turning radius problems. It also required MUST II spindles and that usually limits disc brake size to 11".
Unless you are a fabricator and have a nice shop to experiment in, a ready made kit is advisable (IMO).
Old 08-31-2006, 12:08 PM
Sacred Steel
Thanks, These are the replies I expected, I'm just branestorming. I'm going to Fall Carlisle next month and I am going to look for a ford powersteering box that matches up or is atleast close.
Old 08-31-2006, 06:12 PM
aka Duke of URL
You know something? FORD put integral P/S on the BIRD in 1961. They kept the Saginaw design on the big FORD (and intermediates). Don't quote me on this (as I am getting a little old) but I know I have come across references of retrofitting that system back to a SQUAREBIRD. Something to think about.
The only other alternative I can think of (to keep it all FORD and other than waiting on Wurth-It/GM rack) is to have a x-member made up to accept the popular MUST II steering conversion. I would use the later FOX rack and you are limited to the MUST spindles (front steer) but I would adapt them to keep the BIRD control arms and suspension. Something else to think about.
ROD AND CUSTOM MOTORSPORTS
Is your BIRD a dedicated restoration or a cruiser?
Old 08-31-2006, 06:57 PM
Sacred Steel
That sure is something to think about. My father has a 62 so when I go down there I will look at his box.
My bird is a cruiser for sure. Check it out.
Old 08-31-2006, 07:36 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
www.borgeson.com might be a good source as well as they do a lot with that style of steering box and may just be able to provide one that is bolt in..
I have has some success with those cars by just replacing worn parts with new or rebuilt..made a whole new feeling car out of the deal..
Sam
Old 08-31-2006, 07:44 PM
redlightning's Avatar
http://www.y-blocksforever.com/tech/html/r_p.html
This is on a 56 Ford.
Old 08-31-2006, 09:09 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Mark
This is a little off-topic, but there's something wrong with the formatting on that article. It comes out as 4 very long lines (with a huge horizontal scrollbar) instead of wrapping the lines.
Old 08-31-2006, 11:10 PM
powerrodsmike's Avatar
Wiki Edits: 161
Astroracer, That is an excellent article and the longacre link is VERY informative. Is that in the knowledge base? If not, it should be.
later, mikey
BE different....ACT normal.
Installing Rack and Pinion on 70 Camaro Rick Beil Suspension - Brakes - Steering 3 10-04-2005 04:14 AM
manual rack and pinion for rear steer needed Olds 69 Suspension - Brakes - Steering 7 03-25-2005 01:29 PM
rack and pinion 1955 chevy truck chevy551958 Suspension - Brakes - Steering 1 09-20-2004 02:40 AM
center steer rack and pinion curtisstarlight Suspension - Brakes - Steering 2 02-05-2003 07:00 AM
Rack & Pinion Paul Pouse Suspension - Brakes - Steering 3 03-01-2002 06:42 AM
