Building a Rotisserie for 68 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2007, 08:58 AM
jusglazin's Avatar
NOVA MAN
Anyone have some plans or a guide that they can share on how to build a SAFE and Functional Rotisserie for a Camaro. I need one to work on a new project that I have.
Old 01-19-2007, 01:17 AM
Check out CDJr's home page. There's pics of one with a 1st-gen Firebird on it.
http://home.sport.rr.com/cdjrracing/
Old 01-19-2007, 01:26 AM
Bare Knuckles Champ
Last journal entry: Made a wrench...
Here are 2 links I've saved...
http://members.tripod.com/~mopar_roa...otisserie.html
http://prostreetcar.com/body_rotisserie.html
Show us what you build!
Old 01-19-2007, 08:27 AM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
www.autobody101.com has plans that I modified for my project. I put more length on the upright could have used a couple more inches as it would only go to 90 degrees not a full spin.
You would have to figure out mounts for your particular body though.
There's pics of it in my gallery
Old 01-22-2007, 02:30 PM
In my photo gallery is a rotisserie plans that I got out of Auto restorer book,my friend made one for his 70 cuda,it was way over built for that car,it is strong enough to hold up your car with no problem. it is a very nice unit.
Old 02-07-2007, 12:25 PM
Rotisserie
I made one 25 years ago to build stock cars on. I made mine out of spindles from a American Motors car. The spindale bolt on and can be used in a number of ways. I bolted mine to a triangular shaped base on each end of the car.You can leave the wheel on it and weld box tubeing to the wheel and fabricate brackets to fit the frame / body you are working on. If you leave the brake on it you can plumb in a bottle jack to hold car in desired position. Chevelle and El Camino spindles also bolt on and can be found with disk brakes. I will post photos if i can locate them.
Caution "must" be used as you seldom can rotate without help as finding center mass of car will be difficult and a counter weight bolted on may be nessary.
....Another idea is to make 2 overly large shaped stop signs (hexigons) out of 2x2 or 1x3 boxed tube. end result must be at least 6 inches wider than the car / truck is wide. with cross braces from side to side. bolt the car to the cross braces and have beer party for enough friends to roll the car to which ever side you want. You should plan ahead and make a 'kickstand' that can be bolted in place on one end or the other to keep from tipping over in the event it is lopsided in weight.
Old 02-23-2007, 02:38 PM
Lurker...
Search "rotisserie" over at http://www.camaros.net/forums/ There are several home built ones to look at.
Old 02-26-2007, 11:20 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Check the Crankshaft Coalition Wiki. It doesn't show up on the front page for some reason, but here's the link:
http://www.crankshaftcoalition.com/w...ame_Rotisserie
Old 03-04-2007, 03:12 PM
I've got some stuff on a rotisserie for a chevelle, out of engine stands that might give you some ideas, on my site.
Rob
http://www.1969supersport.com/
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-29-2010 12:06 AM
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 12:01 PM
building a 1984 camaro drag car z28camaro1984 Engine 19 04-18-2005 12:38 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 01:30 PM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 10:29 PM
