Building a sheetmetal brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 09:11 PM
Grand PooBah
i started building a sheetmetal brake 3 days ago. i used the plans from my site somewhat and added to them as i went..
i also made the clamp plate spring loaded for easier operation,also designed it as i went..
i need a little smaller spring, the ones in the last pic are some i had laying around and just stuck them in there to test it.
i've taken some random pics as i progressed through the build, hope you find them useful...
the biggest problem i had so far was positioning the hinges, took me 4 times of tack welding them and testing. The hinge pins have to be centered with the 2 pieces of angle iron, and also level and square... if i would have known how much of a pain it would have been to locate them i would have machined the hinges with locators on them before hand...
i'm not completely done with it, i still need to add some adjusters for clamp plate forward and back spacing for metal thickness, and the handles and a stand...
building a brake is not a quick and simple job... it is a fun one though..
i'll add more pics as i go.
ID:	49807   Click image for larger version
ID:	49808   Click image for larger version
ID:	49809   Click image for larger version
ID:	49810   Click image for larger version
Old 11-08-2010, 09:14 PM
Grand PooBah
here are a few more pics
ID:	49812   Click image for larger version
ID:	49813   Click image for larger version
ID:	49814   Click image for larger version
ID:	49815   Click image for larger version
Old 11-08-2010, 09:15 PM
Grand PooBah
and the last few pics so far.
ID:	49817   Click image for larger version
ID:	49818   Click image for larger version
Old 11-10-2010, 06:14 PM
Grand PooBah
i got most of the stand built today...
when i put the angle iron across the the 2 legs at the bottom i spaced them out 16 1/2 inches apart so a cinder block would fit between them, just in case it wanted to tip i could add blocks for weight on the bottom of base..
actually dont think i'll need any blocks after i got it together somewhat...
i just have the brake clamped to the stand for now, i'm going to make some mounting brackets and bolt it on..
after i got the stand made i think i might make a small fold out table/bracve to help hold up a somewhat longer piece.. i think that would be a nice addition..
ID:	49944   Click image for larger version
Old 11-17-2010, 06:34 PM
Grand PooBah
i added the 2 angle pieces in the center, below the brake...
i still need to add the bending handles and the casters...
i went ahead and just welded the brake to the stand, dont think i'll need to be taking it off for any reason... when i added the clamp springs i had to notch the hinges so they would go past 90 degrees..
heres some more pics...
Old 11-18-2010, 08:51 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
what size material you bending or plan on?
Old 11-18-2010, 06:47 PM
Grand PooBah
18ga max... might try 16ga.
Old 02-09-2011, 06:14 PM
this is a great lookin setup, im sick of the vice trick. have you tried it on 16 ga. yet? thanks
Old 02-16-2011, 08:30 PM
Grand PooBah
havent got a chance yet..... i just bought a mill so i got side tracked with some odd and ends stuff and the mill... i should be able to try it in a week or 2
i'll let you know
Advices on brake system repair 78 Monte rack Suspension - Brakes - Steering 5 01-12-2009 08:32 AM
Advantages -pitfalls of relocating parking brake to tranny hump Ripped Suspension - Brakes - Steering 1 09-01-2005 01:47 PM
Sheetmetal brake Yukon Cornelius Body - Exterior 1 06-06-2004 06:35 AM
diy sheetmetal brake? jon_volk Body - Exterior 4 11-19-2003 04:42 PM
