Building steering column from scratch... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 05:57 PM
Just happy to be involved :)
Hi All, Failing that I find a tilt column from and early 60's Mopar without a keyed ignition on it to install into my 55 Dodge 1/2 ton truck ...I was wondering if anyone had seen an article in a hot rod mag a few months ago about home building a straight sterring column from just tube and bearings
etc...I ( of course ) did NOT buy this mag when I saw it...but I'll just add that to the long list of dumb things I want to kick myself over...
Any body done this type of thing?
Best regards,
Derek
Old 01-27-2006, 06:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All those are is a tube with a nylon bushing at either end to support the shaft..bushings could be brass or bronze for that matter..Most common is a quick release hub for the steering wheel..turn signals box can be a clamp on unit from JC Whitney..you will need a couple of collars with set screws to retain the shaft..
Try the race car suppliers for the parts and if you have an industrial supplier they can provide the bushings and collars..
Of course Art Morrison has the whole deal in stock so there you go..that is the easy way..
Real common deal in race cars..
OMT
Old 01-27-2006, 09:33 PM
I've got that mag in front of me. It's Rodders Digest August 05. Not sure how I could get the article to you. If I was better at this I could scan it and send it to you. I'll try and figure it out if you want. Just got a new printer with the scanner, and I think I can do that if you want me to email it to you.
Old 01-28-2006, 07:45 AM
I have a similar printer scanner deal...mine just has a one button scan.
I'd be willing to send some postage and whatever you need for a photocopy of the article as well....but the emailed file should work as well..
There is no rush, I'd be greatful if you could see fit to scan it at your earliest conveneince...its cold here in Ottawa and I wont be doing much for a bit anyways....
Thanks for the posts !
Derek
Old 01-28-2006, 08:39 AM
C9x C9x is offline
Here's a pic of a home-built aluminum steering column with sealed ball bearings both ends.
Cost about $35.
Uses a length of 1 5/8" OD aluminum tubing, .120 wall.
A stock length GM straight steering shaft - 36-37" long depending.
You don't need a tilt column if you place the column properly.
Ergonomically speaking.
The only things you may have to farm out are the bearing adapter bushings at both ends as well as the locking collars top and bottom.
If you have access to a lathe, you have it made.
This particular column is set up for a quick-release hub.
It goes into a 31 on 32 rails roadster.
The in-car pic shows a different column mount than the first photos show.
Name:	Str Column 2x.jpg
ID:	9612   Click image for larger version
Name:	Str Column 5x.jpg
ID:	9613   Click image for larger version
Name:	Str Column Hamb.jpg
ID:	9614   Click image for larger version
Old 01-28-2006, 03:26 PM
Hey Derek,
I scanned the mag pages you want, but seem to be having trouble attaching them. Comes up "cannot find server"when I try. Any suggestions?
John
Old 01-29-2006, 11:29 AM
home built column
hi all, just taking a quick second to note that we were called into hospital to enduce my wife for our first child...nothing as of 24 hours, but I just stopped off at home to freshen up and get some new threads.........
will be checking back in asap....
tty all soon, Best , Derek
Old 01-29-2006, 01:14 PM
MI2600's Avatar
Member# 3287
You could also check the Ididit site.
Old 01-29-2006, 02:20 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Yup Rodders Digest had that article. If I still have it (will check my stash of mags later) I could possibly send you a photocopy of the article. Ill check for you later.
C9x that looks good, is that in your rod???
Mike
Old 01-29-2006, 04:05 PM
C9x C9x is offline
Mike
Thanks.
The column pictured goes into my 31 on 32 rails project roadster.
I have another in my 32 roadster that has over 43,000 trouble free miles on it.
Cept for the time the elec fuel pump died and the other time the metering rod stuck open.
Other than that, a problem free little car.
Here's a pic of the one in my 32.
A little more street oriented with the larger adapter under the wheel.
I like to make all the stuff I can and there's more home-made stuff in the 31 than there is in the 32 although there's quite a bit in the 32.
Attached as well, a pic of the 32.
Both cars run 462" (.030 over 455) Buick engines.
ID:	9667   Click image for larger version
Name:	32 - Fillmore 2004 - jpg.jpg
Old 02-07-2006, 12:05 AM
Home built steering column
Hi Derek,
I hope everything went well with the baby and all.
I finally figured out the file from the scanner was to big. It was huge. Been playing around with the program to reduce the size. Couldn't figure it out. Finally emailed it to myself so I could save it in a program I knew how to work. Anyway, I hope you can read it, and that it helps. Good luck!
John
Name:	steering column 1.JPG
ID:	9890   Click image for larger version
Name:	steering column 2.JPG
ID:	9891   Click image for larger version
Name:	steering column 3.JPG
Old 02-20-2006, 05:59 PM
photocopies anyone?
Hi all, my pc cant seem to get the scans any clearer....and my time to fiddle is limited helping my wife ( now "mom" ) with out new addition to the family.
Anyone able to photocopy this article and mail it if I send postage and an envelope, or just look for a few buckjs for a used copy of this Rodders Digest?
Will check in again asap,
I really appreciate the lengths everyone has gone to helping me with this deal...nice to see.
Derek
Old 02-20-2006, 09:36 PM
Hi Derek,
If you have a fax available I'll fax it to you, or just give me your mailing address and I'll send it that way.
Old 02-20-2006, 10:12 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Congrats on the new baby! Boy or girl? Been there done that, boy and girl. Hockey, ball, basketball, volleyball, dance, figure skating, university, lots of time and money. Didn't know what I was missing till I had them. Both have left home and started their own family lives. Time for me now to start building those hot rod things again.
Old 02-20-2006, 10:44 PM
Hey Derek,
I'm trying to up load the files again. I think I have left them bigger this time.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
custom steering column Blob Suspension - Brakes - Steering 5 07-08-2005 01:28 PM
34 ford steering column vette66guy Suspension - Brakes - Steering 3 06-01-2003 07:04 PM
shortening the steering column smoran Interior 3 05-02-2002 06:38 PM
