Building a STREETABLE BBC for spray
Hey everyone, I'm looking for help building a BBC for spray that I can still drive everyday. It's a 468 with Eagle forged internals and trick flow 280cc heads. It and 11:1 compression it puts down about 620hp. I want to be able to run a 300 shot in it but I'm worried about melting a piston or breaking something with the internals.
My questions are: Will the initial "hit" hurt a BB w/ forged internals? Or should I use less spray? Can I do a 300 shot with a two stage kit or will that make a diff? What are things I need to concider when building a nitrous motor? |
I agree about the fuel and retarding the ignition for sure. What about that initial "hit" of no N2O to a 300 shot? Is a twin stage system worth while in this case or should the NOS be "ramped" up over a second or so? And also what is the limit of how much you can VERY RELIABLY spray a BBC? Hp wise?
![]() You also need the drivetrain (transmission, rearend, etc.) to handle the HP. Again, don't worry about breaking any of those parts either.
It would be going in a mud truck. What's the post likely thing that will break on it?
make sure you have plenty of RPM when you hit the button or you can break a rod. Ring gaps need a little extra space as already noted. On a mud truck there's no telling what drivetrain part will give out.
It'd be fun to set up a little bet on which parts will fail next. Mud trucks place a very high and inconsistent load on an engine and drivetrain- makes it fun to guess what will happen. |
Don't RPM that motor up before you hit the button. Make sure your well below the redline of the motor. In the mud... When you hit the button your motor's gonna rpm instantly since you will have so much wheel spin.
Watch your fuel pressure. You better off having a dedicated fuel pump. One cough and its bad new. |
| building a BBC for mudd boggs | inquiring_mind2 | Engine | 0 | 09-27-2011 09:12 AM |
| Scratch building with spray foam - wow. | cboy | Hotrodders' Lounge | 6 | 09-15-2009 07:18 PM |
| Building a blown 468 bbc [ questions] | Bad Rat | Engine | 8 | 12-08-2006 11:49 AM |
| building a bbc 427 | inquiring_mind2 | Engine | 4 | 11-16-2006 02:18 PM |
| sugestions for building a blown BBC | Bad Rat | Engine | 5 | 11-18-2003 10:36 PM |
