Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building Trailer Wire Test Box Couple Questions.
Old 12-26-2011, 10:24 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Sounds to me like this has been over complicated for my ole brain..All i did was to use a standard fuse panel with the flasher circuits in it and wired it to a trailer plug and had a couple of leads that went to the battery with alligator clips like the ones on jumper cables..Worked for me. I also had a four pin connector on it so I could check lites on little trailers as well. this all went in a small toolbox.
Sam
