Building a tubular dropped axle - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-30-2013, 02:28 PM
Elevinpointsixtoone's Avatar
I believe the max drop I've seen on a retail axle is 5". You can run a flat front cross member vs. the stock that drops down. You will pick, what, 2" of drop just by moving the spring center mount up with a flat cross member? Run a reverse eye spring, take out a couple of leaves or go mono leave and you just dropped more.
Check out this guys stuff: Ricky Bobby's Rod Shop...these are freakin vacums they are so low.
Ricky Bobby
front tubular axle drop
dropped axle tomgru Suspension - Brakes - Steering 2 01-30-2012 06:41 AM
dropped axle 65shelby Suspension - Brakes - Steering 7 09-26-2011 05:27 AM
Dropped Axle Mr.E Suspension - Brakes - Steering 1 07-21-2004 11:47 PM
Dropped Axle adtkart General Rodding Tech 5 12-27-2003 07:45 PM
Dropped Axle adtkart Suspension - Brakes - Steering 3 03-30-2003 05:46 AM
