building vortec motor Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 05:45 PM
hey,
im builing a vortec motor motor with a comp cam roller cam in it with some comp cam hydraulic lifters also Self-Aligning Rocker i was wondering if i could use the same stock Pushrods or do i have to get some stronger pushrods??
Old 10-18-2012, 06:08 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Unless you changed to a higher lift cam and/or stiffer valve springs, the stock pushrods will be fine BUT you have to check the geometry of the valvetrain to find out if the stock pushrod length will work.
Old 10-18-2012, 06:56 PM
techinspector1's Avatar
Wiki Edits: 326
Here's a link to CompCams site explaining pushrod length....
COMP CamsŪ - Pushrods
Old 10-18-2012, 09:38 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
What kinda cam/lifters came out of it...what parts are you re-using?
Factory roller lifters use a different pushrod length
Aftermarket retro lifters use a different pushrod length
Flat tappet lifters use a different pushrod length
new to motor building lrosas Introduce Yourself 2 01-11-2012 01:48 PM
building a 305 w/350 vortec heads bowtiebill Engine 30 03-04-2011 05:45 PM
building a new motor 1978 corvette Engine 4 08-05-2010 10:52 AM
Building a vortec 350 Dodgeman7979 Engine 30 11-09-2009 11:36 AM
Building the Vortec 357ci 04SilveradoMykk Engine 2 08-20-2008 08:00 AM
