Building your own sandblast cabinet - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-06-2008, 12:21 PM
Self Build Sand Blast Cabinet
Originally Posted by lemans-tom
Here is a picture of my cabinet that I have constructed. Its not pretty but it works perfectly for the resto of my 69 Le mans.
It comes as a self build kit here in the UK and includes all fixtures, fittings, plans, cutting tables, instructions etc. All you need to add are your time and two 8 x 4 plywood sheets.
I run it off my 3hp compressor and dust extraction is via an old vacuum cleaner. The windows, which are polycarbonate, are covered on the inside with film which is sacrifical. Once this is abraded and vision is poor, I remove the window, replace the film and vision is restored.
Hi,
Can you let me know who supplies the Self Build Kit please?
  #17 (permalink)
Old 05-06-2008, 01:15 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Did you realize that, that post was made nearly 4 years ago? That member is still very active on this board though. If he does not see this and respond to it....you can send him a PM.
  #18 (permalink)
Old 05-07-2008, 02:56 AM
Thanks for pointing that out Henry you are of course correct. But I'm still here (like the proverbial bad penny)...........................
Address for the supplier of self build is below. I've checked they are still in business.
Anglo Scot Abrasives
5 Bolton Road, Ashton-In-Makerfield, Wigan WN4 8AA
(01942) 270729
Just for the record I still use mine, its probably been built about 5 years now and have had no real problems with it other than a bit of essential maintenance. A great bit of kit.
