Building your own sandblast cabinet
While going thru some of my old bookmarks to see what they were I ran across this and thought I'd share. It directions on how to build your own sandblast cabinet.
Sandblast Cabinet |
Thanx!
thanks kevin
sanblasting cabinets
Here are some pictures of the cabinet that I have constructed. It was bought as a kit here in the UK. It includes all the hardware and fixtures, fittings etc. It provides you with a plan, cutting table and assembly instructions. All you need to supply are 2 8' x 4' sheets of plywood and your time. Dust extraction is via an old vacuum cleaner.
I hooked it up to my 3hp compressor and it works perfectly. |
Here is a picture of my cabinet that I have constructed. Its not pretty but it works perfectly for the resto of my 69 Le mans.
It comes as a self build kit here in the UK and includes all fixtures, fittings, plans, cutting tables, instructions etc. All you need to add are your time and two 8 x 4 plywood sheets. I run it off my 3hp compressor and dust extraction is via an old vacuum cleaner. The windows, which are polycarbonate, are covered on the inside with film which is sacrifical. Once this is abraded and vision is poor, I remove the window, replace the film and vision is restored. |
Thanks Kevin
plans?
Any chance anyone can give me the name of the company that sold you the plans? Im building a cabinet very similar, but am having alot of trouble making the catch basin, or bottom portion of the thing. Im in need of some definite measurements for sections of the bottom, or failing that, an idea for something to use that measures 51 x 18 with a funneling action.
Any ideas guys? I came over here from a google search, but if there are any wwII jeep enthusiasts here, check out another forum - g503.com, excellent place to get advice and help. on jeeps anyway. |
hopper details
I'm attaching some pictures of the hopper in response to Jeepster as I had trouble trying to figure out how to attach them to pm.
Should be four in total, but may have to make a further post if I run into file size problems. |
You could also check out these guys. I ordered their plans a while ago and found them very detailed and the site has good info on blasting accessories and hookup.
http://www.tptools.com/prod_list_dis...69VWDD6EUJ9DC7 |
thanks!
Thanks a bunch guys! I appreciate all the help. This really is what I needed to see to move my cabinet along. Thanks again!
Wow thanks for the info Kevin . I have been useing my
sand blaster out in the open this would be much cleaner. Im gonna try and build one .Ill let you know how it comes out. |
| Recent Garage - Tools posts with photos |
