built 305 tpi timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 10:47 PM
the motor is a 305 tpi that is surpose to be bored 40 over with a small cam and that is all i know the timing is not just right at the moment and i was wondering what should i set the timing at since the motor is built
Old 03-16-2010, 02:01 AM
DoubleVision's Avatar
The timing should stay close to the stock setting. After you set it the computer will pretty much take over adjustment from there.
305 TPI problems BlackCamaro Engine 7 04-15-2010 12:20 PM
1986 305 tpi zaroths Engine 41 05-20-2009 08:42 PM
SBC 283 and 305 With TUNED PORT INJECTION TPI boneyard Buick Engine 14 07-11-2005 01:49 PM
Tpi 305 To 350 Teejay68 Engine 3 11-26-2004 12:43 PM
Carb'd 305 to TPI 305, help? coolerow Engine 2 09-23-2003 03:10 PM
