Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Built 350-Timing Set Question.
Old 11-08-2012, 09:34 PM
cdminter59 cdminter59 is offline
Check the front left-hand side of the block. There is a pad behind the alternator with some numbers stamped on it. Also check the flange where the transmission bolts to the block. Drivers and passenger side. There is a casting number on that flange. Check out this website to decode block numbers. If you need help post the numbers here.
The Following User Says Thank You to cdminter59 For This Useful Post:
fastnloud (11-08-2012)
