Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Built 350-Timing Set Question.
Old 11-08-2012, 09:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by fastnloud View Post
Hi, I'm new here
I have a 82 GMC Sierra with a built 350, I will be adding a hydraulic flat tappet cam and lifter set among other things soon. I was wanting to go ahead and get a double roller timing set for it. Will a timing set for a 350 fit any year of the 350? Because I don't know what year the motor is that is in mine, it's not the stock motor.
I was looking at this
COMP Cams Magnum Double Roller Timing Sets 2100 - SummitRacing.com
Thanks guys.
The main place you can run into problems is if you have a factory hydraulic cammed engine. If it has a flat tappet or retro roller cam, the set you linked to will work.
The Following User Says Thank You to cobalt327 For This Useful Post:
fastnloud (11-08-2012)
