Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Built 350-Timing Set Question.
Old 11-08-2012, 10:48 PM
fastnloud's Avatar
fastnloud fastnloud is offline
Originally Posted by cdminter59 View Post
Check the front left-hand side of the block. There is a pad behind the alternator with some numbers stamped on it. Also check the flange where the transmission bolts to the block. Drivers and passenger side. There is a casting number on that flange. Check out this website to decode block numbers. If you need help post the numbers here.
