Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Built 350-Timing Set Question.
Old 11-08-2012, 10:16 PM
idontdrivericeieatit idontdrivericeieatit is offline
Built and hydraulic flat tappet cam is not two words I put in same sentence but your answer to question is no the old two peice rear seal engines and the newer one peice rear seals engine require a different timing chain un less they have a universal type I dont know if they do and dip stick can help you determine engine age a little is it passenger or driver side dipstick older blocks are driver side
The Following User Says Thank You to idontdrivericeieatit For This Useful Post:
fastnloud (11-09-2012)
