Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Built 350-Timing Set Question.
Old 11-08-2012, 10:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by idontdrivericeieatit View Post
...your answer to question is no the old two peice rear seal engines and the newer one peice rear seals engine require a different timing chain un less they have a universal type I dont know if they do...
Nope. The difference is whether the engine is running a factory type hydraulic roller cam/block/thrust plate. It uses a different bolt pattern than the flat tappet cammed engines and the clearance on the back side is different to clear everything. The linked to timing set will work for any flat tappet engine through about '91 when the Vortec began.
The Following User Says Thank You to cobalt327 For This Useful Post:
fastnloud (11-09-2012)
