Built 350-Timing Set Question.
Hi, I'm new here
I have a 82 GMC Sierra with a built 350, I will be adding a hydraulic flat tappet cam and lifter set among other things soon. I was wanting to go ahead and get a double roller timing set for it. Will a timing set for a 350 fit any year of the 350? Because I don't know what year the motor is that is in mine, it's not the stock motor. I was looking at this COMP Cams Magnum Double Roller Timing Sets 2100 - SummitRacing.com Thanks guys. |
Check the front left-hand side of the block. There is a pad behind the alternator with some numbers stamped on it. Also check the flange where the transmission bolts to the block. Drivers and passenger side. There is a casting number on that flange. Check out this website to decode block numbers. If you need help post the numbers here.
Built and hydraulic flat tappet cam is not two words I put in same sentence but your answer to question is no the old two peice rear seal engines and the newer one peice rear seals engine require a different timing chain un less they have a universal type I dont know if they do and dip stick can help you determine engine age a little is it passenger or driver side dipstick older blocks are driver side
If the one he has is old style then he should be fine because its not a vortec engine from way hes talking
are you saying the 87 to 90 roller blocks you can put old timing chain cause thats when gm went to roller in camros and vettes in The 350 not at 91 with the vortec or is it just the vortec engines that are a problem with the chain?
As long as he's not using the factory block/hydraulic roller cam/thrust plate he's fine, yes. That could be an engine from around '87 until the Vortec started. The factory used hydro rollers and flat tappets at the same time. Trucks/TBI engines got the flat tappet cams.
Yea I dont think he has a roller block but thats good info for me I always heard you couldnt run old style in the roller style blocks starting in 1987 but I guess to thats my fault never thought to ask if I change cam to non roller cam would it be possible
Thanks guys. The dipstick is on the passenger side of the block.
I do understand roller cams are better and also more expensive, but I think there are plenty of nice street rods with hydraulic flat tappets. |
Attention to detail used to be enough. But now a big problem w/flat tappet cams is the influx of poor quality cam cores and lifters that make them more failure prone than they should be. Add to that the motor oil being made w/less high pressure additives that are needed when using a flat tappet cam, and the chance of improper break in procedures being followed and you have a system that fails more than it should- and more than it did, not that many years ago. But that said, if the proper parts are used (like the correct valve springs set up w/the correct installed height), and the important areas of the valve train are checked, and the proper procedures for cam break in are followed, there's no reason a strong running engine cannot have a flat tappet cam- even a hydraulic flat tappet cam.;) |
Yeah, I will be using Valvoline VR-1 as my motor oil as it has plenty of Zinc/ZDPP, and a break in additive the first time as well. |
| All times are GMT -6. The time now is 11:56 AM. |
