with the compression, have you considered shims? they replace the factory metal that was milled away when you shaved the heads. what you get is the starting point of the heads. with the cam, since its in a k10, i would go with as much torque as possible, get a good cam for off-roading and you should be set. with trucks bottom end is the way to go! ADAM
