Bulb Numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 05:54 PM
Bonafide Old Car Nut
Bulb Numbers
I read a thread the other day about what bulb replaces an 1157 that is brighter on the brake and turn signal and now I cant find it!!
Could someone please tell me what that number is and any other numbers that would replace older numbers with brighter and more durable bulbs.
THANKS MUCH!!!!
Old 09-04-2006, 06:28 PM
Wiki Edits: 31
the bright bulbs are dual fillament and generate a lot of heat. I'll suggest the replacement LED bulbs, that fit in place of regulars. there made for 1156's and 1157's and are available thru speedway, and so are the brite bulbs.
Old 09-04-2006, 08:10 PM
Bulb Numbers
Thanks for the info on LEDs but what I am looking for is that number which replaces the 1157. The tail light filiment is the same as the 1157 but the brake light filiment is supposed to be noticeably brighter. Also, if there are otherbrighter and more durable replacements for other numbers such as which is brighter, a 194 or a 168--- which has more candlepower. Any information or a chart or something would be greatly appreciated.
THANKS AGAIN!!!!!
Old 09-05-2006, 10:34 PM
http://www.litebulbs.com/appchart_minilamps.html might have what you want. Check #2357.
Old 09-05-2006, 10:51 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
That's a great site! Thanks jimfulco.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-08-2006, 08:25 PM
Bulb numbers
Thanks guys for the input! jimulco, that chart is exactly what I was looking for. My El Camino thanks you to!
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 11:02 PM
1932 Ford serial numbers jimpa General Rodding Tech 1 06-09-2004 09:24 PM
need help on holley numbers notmrgoodwrench Engine 6 10-25-2003 08:20 AM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
replacing headlight bulb mmalkawi Electrical 2 07-31-2003 08:50 PM
