Bummed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 10:34 PM
Last journal entry: Gas cap next
Bummed
I bought fiberglass fenders (2" wider) for my 41 Chevy Coupe. Deep down I probably knew that it had been rear-ended at some point in time, bit I was in denial. Well guess what. The fenders are too long. I'm having to cut a section out of each fender to make them fit.
I don't know a thing about fiberglass, but I will when this is over.
Old 11-03-2011, 10:39 PM
life is a temporary assignment
It isn't as hard as you think..
Take a look in my journal,, It show me making some fenders from scratch... It might give you some idea's..Good luck..Randy
Old 11-04-2011, 09:17 AM
deadbodyman's Avatar
Wiki Edits: 11
It a little late now but why not just widen the metal fenders 2" ?
Old 11-04-2011, 11:28 AM
Of course, the body may not be wrong, the fenders could be.
Old 11-04-2011, 11:42 AM
Bummed
I think it's a little of both. I know that it was hit from behind before and I was told thefenders would be a tight fit. So a little here and a little there makes for a 2" adjustment.
Old 11-04-2011, 11:56 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I found this nugget of info on one site:
"**** NOTE: Some customers have experienced installation issues with this fender. We have personally installed these on a customer's car and it is a tight fit. On some cars, modification of the fenders may be required to complete the installation. This can include cutting and re-fiberglassing portions of the mounting flange. Because of the possibility of having to do this rework, these fenders are offered at a 33% discount (regular price ****) but they CANNOT BE RETURNED.
Based on the original part, with two inches added to accomodate wider tires. Measures 57" x 24", and a wheel well of 27"."
When they make the fender wider, will the 2'' not continue to taper forward and back giving it extra length?
Old 11-05-2011, 08:29 AM
Wiki Edits: 11
Fiberglass aftermarket parts are notorious for a terrible fit.
Even if the car was hit and repaired the car might be fine ...look at how well the deck lid fits and if it has nice even gaps all the way around then examine the fenders for excessive body work....if the old fenders fit well and you really want fiberglass its a save bet they are the problem so start cutting and fitting...when the time comes to start glassing use the stranded mat not the woven type its a lot easier to work with...Lowes or Home depot have about the best deal on resin 35.00 a gal for 3M compared to the body shop supply stores 58.00 a gal...
TH350 screeching now. I'm bummed! Jmark Transmission - Rearend 7 05-11-2004 07:18 PM
