Bump Steer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2011, 10:32 AM
Bump Steer
I have 1931 ford StreetRod and have Mustang 2 crossmember with southernrod upper and lower tubular cafframes and 2 inch dropped spindles, when I hit a bump or a hole in the road I get bump steer which jerks my Steering wheel, Ive had it Aligned and they didnt do a very good job so I set it up myself, Ive seen where other aftermaket mustang type cross member have where the rack and pinion bolt on extended out away from the cross member and the rack it tilted up more, on my car my tie rods are not straight with my lower afframes if I was to weld perches like they do would this take out the bump steer. Thanks Ed
Old 08-28-2011, 11:45 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Post us some pictures of your set up.. Then we maybe able to help you better..
Old 08-28-2011, 12:03 PM
bump steer
i will as soon as i can get it on a lift to take pics of it
Bump steer? squids1 Suspension - Brakes - Steering 5 03-20-2009 01:32 PM
could it be bump steer? Augusto Suspension - Brakes - Steering 2 04-05-2007 09:33 AM
Bump steer on this one? staleg Suspension - Brakes - Steering 6 11-29-2006 01:20 PM
Bump Steer al_32_ford Suspension - Brakes - Steering 5 05-01-2006 05:19 PM
bump steer A40eh Suspension - Brakes - Steering 4 11-23-2003 03:01 PM
