Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bump Steer Kit Questions?
Old 07-27-2012, 09:13 AM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
As problem is that my spindles are set up for a 7" throw side to side.
1) Making a conversion parts like the Mustang Bump steer would shorten the steer arm by 1" and allow me to use a Cavalier r&P with 6" throw.
Othe options I'm considering are:
2) Use the GM gearbox that came from the 95 Roadmaster and shorten the center link so that the tie rods connections are in line with lower control arm pivot. Advantages: Uses more of steer system I already have and cut and sleeve cross link simple modification. Disadvantage: End up with looser steering typical of '95 Roadmaster and future replacement of gearbox would be costly.
3) Take a 7" side to side R&P with end take off and convert it to center take off with a cross member like attached picture. Advantage: End up with tighter steering because or R&P and R&P replacement lower cost in future. Disavantage: Have not found anyone who has done this, but think would be possible.
What do you experts on car building think would be best path?
Thanks
