Bumper mount question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2009, 07:52 PM
T-bucket23's Avatar
Wiki Edits: 26
Non hotrod related.
Someone backed into my daughters 1996 Saturn SL2 today. The hit the front bumper on the left corner. It is loose now on the end. Moves in and out a couple inches. Does anyone know what would normally hold this in place. Is it just some sort of plastic clips or something easily fixable. I can put it up on the lift until saturday and would just like some idea of what I might actually be looking for.
Body work is not my thing
Thanks
Chet
Chet
Old 04-07-2009, 08:26 PM
fast68's Avatar
likes chevy trucks & boobies
well every vehicle varies
but most bumper covers are held on by round pushbutton clips
and they are probably missing now
look and see
if there are lots of empty holes under there and no clips or broken ones then well that the problem
you may be able ot go to any local body shop and pick some clips up for free or cheap and possibly make your bumper cover stay up for now.
the fix if the bumper cover is ripped or damaged other than being scuffed is to replace it with another one from the yard or from an autobody parts company online or local
good luck
Old 04-07-2009, 10:03 PM
Your Saturn has a metal plate under the edge of the bumper on both sides. The fender has two bolts that hang down under the edge that the bumper slips into. The metal plates on the bumper have slotted holes in them that fit over the bolts as you slip the bumper on. The fender liner has a couple of small sheetmetal screws with a 7mm head on them that go thru the liner into the number where a "J" nut is. I would say, you need to unscrew those littel sheetmetal screws from the liners (there are three on each side). Then open the hood and remove the three push in retainers that hold the top of the bumper to the upper reinforcement. Under the bumper there are three or four down there as well.
After those are removed the bumper pulls forward off those bolts under the fenders.
After removing it, simply push it back on hanging it back up on those bolts under the fenders and put all the screws and retainers back on.
It is pretty fool proof.
Old 04-09-2009, 04:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks, I will take a look at it. Just wanted to know what I was in for.
Chet
Old 04-09-2009, 07:58 PM
I have to tell you, I love those damn cars. I worked at a shop for a while that specialized in them, about 90% what we did was Saturns.
They are the closest thing to the VW Bug America has ever had. They are plain common sense, that is all I can say. If you look at them like you know nothing about a car you will be fine. If you look at it like other late model cars you will be frustrated.
They are a little different, but total common sense designed.
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Engine mount question v8muscle Engine 2 07-16-2008 07:12 PM
Eng mount & Frame boxing QUESTION 39chevy Hotrodding Basics 1 01-10-2007 08:40 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
