-   -   Bumper stops (http://www.hotrodders.com/forum/bumper-stops-231487.html)
rustman 04-04-2013 01:17 PM
Bumper stops
I have a 36 Ford pickup with a Mustang 2 IFS. Can someone tell me where the bumper stops would be located. Would they have been incorporated into the original shock itself? Thank you.
aosborn 04-04-2013 11:09 PM
The bump stops are indeed located on the shaft of the orignal shocks.
rustman 04-05-2013 12:41 AM
Thank you aosborn. I am thinking to go to coil overs. Do you know of any with the stops on the shock shaft? I don't think my shocks are stock Mustang II and I see that Jeg's sells regular rubber stops. I will have to look and see if those could be mounted on the lower A arm under the frame. Anyway thanks again.
aosborn 04-05-2013 09:21 AM
QA-1 sells some very nice quality coilovers that have bumpstops available that will go over the shaft.
Bump Stops | QA1 Suspension Components | Drag Racing, Street Performance & Hot Rod Bump Stops
