Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 12-16-2002, 03:25 PM
JAY221 JAY221 is offline
New Member
Post BUMPSTEER
I have a 60 Ranchero with the original(63 V8) aframes still in it. I have mounted a Buick Skylark rack pinion in it at this point. Once I get everything back in it such as Motor/Tranny & all accessories it is my understanding that I should try to achieve a bottom aframe that is level with the ground to minimize bumpsteer. Am I on the right track or at the wrong station? Now with the front end skyhigh the bumsteer is horrible. Thanks for any advice/opinions, Jay
  #2
Old 12-16-2002, 04:33 PM
Lash Lash is offline
Cool
Jay, When you use a rack on an independent front end : If you make a straight line between were the top arm and bottom arm pivot the rack tie rods have to pivot in that line. If there close you might get away with it. If not it will be bumpsteer big time..........Lash <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 12-16-2002, 04:42 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Last wiki edit: How to Rebuild a Rochester Quadrajet 4MV Carbureto...
Last journal entry: Final Fisher Body car restored
Wiki Edits: 21
Post
As lash says, it is important to have the flex joints on the steering gear in line with the axis of the pivot on the lower A-arm and the tie rods on the rack parallel to the line between the lower ball joing and the lower A-arm pivot axis. As long as you have it set like that, it shouldn't have significant bump steer even if the front end is high in the air.
Old 12-18-2002, 05:19 AM
New Member
Post
Thanks guys, I believe I am on the right track. Later, Jay
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
